Model upload not going ahead of schema update. Model not opening from a previous version of Sewergems in Connect 2
Hello Mustafa Muhammad,
Can you please share a copy of your model with us so that we can analyze the possible cause of the issue?
Sharing model files
Larry
Hello Mustafa,
Which version were the model files last saved in? Which version of SewerGEMS CONNECT Edition Update 2 are you trying to open the model into?
Please check the version the model was last saved in by opening the .stsw file in a notepad application. See the below article for details on how to do this;
How to find the version a model was created in and last saved in
Ensure that the model was last saved in a CONNECT Edition Update 2 version. An older model should open in a newer version of the program but the inverse is not true i.e. you can't open a model created or last saved in a newer version in an older version. The below article explains more about this;
Model backward / forward compatibility
Another option you can try is to copy the model files i.e. .stsw and .stsw.sqlite to a separate folder folder and then try opening from that folder. Sometimes some of the output files might be causing this problem.
As Larry has suggested it would help if we can take a look at the model files. Please let us know when you have uploaded them.
Yashodhan Joshi
2K.zip
Please review and let me know if any more files are required.
You have only sent one file i.e. 2K.stsw. To open your model I need both the model files i.e. 2K.stsw as well as 2K.stsw.sqlite. The second file is the database file which is needed to open the model into SewerGEMS.
However, I checked the model file and was able to find out the last version the file was saved in which is 08.11.03.77 which belongs to the Select Series 3 version of SewerGEMS.
https://wetransfer.com/downloads/bc9a23816eb1e7b4555cd1a8535983ce20200204120814/2fca245026454ccf49c63fcd3af51c4220200204120814/e027b7
PFA , I am interested in knowing what's wrong with the file and how to overcome similar problems in future.
