Hi Could you please, Look into the issue whenever I run the model, huge network, its failing. Error is shown as in the image.
Model files are uploaded at https://bentley.sharefile.com/share/upload/960be9c4902a4d7b
Could you please revert me at Dharmendra.CN@arcadis.com
Dharmendra
Hello Dharmendra,
Thank you for uploading model files.
This issue is being worked on through service request, will post it here but for benefit of other users.
Sushma Choure
Bentley Technical Suppport
I couldn't reproduce the error with your model with latest version, which is being used by you as well. I computed single scenario and in batch as well. Model is large with small routing time step, increasing routing time step would help a bit.
There could be issues with output files or with .stsw file, please try following.
Hi Dharmendra,
I think Sushma means to copy only the .stsw and .stsw.sqlite files into a new/empty folder and open the model from that new location and see if it computes without crashing.
Thank-you,Larry
