I have PRV on 12" main. I want to set both sides to be open @ 25 psi. How/where do I set?
Hi Dick Schneider,
This Wiki article - Modeling PRV / PSV controlled by pressure at remote location in the model - seems to specifically address your question. The article also references this article - How does the Pressure Reducing Valve (PRV) work in WaterGEMS and WaterCAD? - which explains how to let the PRV's initial settings determine the valve status for setting_type = Pressure.
Please review these articles (and other related articles in the See Also section of each) and let me know if you still have questions.
Thank-you,Larry
Answer Verified By: Dick Schneider
Thanks for info. Got what I needed.
