Functions for coupling WaterCAD with a programming code
I intend to develop a programming code that aims to apply a dynamic model of the water quality and to perform an optimization of the parameters in its calibration. Therefore I require a computer model to perform the iterative optimization calculations.
The programming code provides the input variables of the model, the body and wall coefficients of each pipe to WaterCAD by adjusting the network at the beginning of each time period. Then, with the results, the program makes use of genetic algorithms to make the calibration of the parameters. The objective function of the optimization is the error between the concentrations measured in the prototype and those modeled in WaterCAD.
Do Bently's developers have functions that allow WaterCAD to be coupled with the program to easily alter the modeling conditions? Which program can be coupled with WaterCAD?
