Is it possible to print worksheets that automatically take the name of the worksheet in flowmaster? IE, if I have "Pipe30in", "Pipe36in", etc worksheets to batch print, I want to create pdfs with those names. When batch printing a lot of worksheets, it is easy to lose track of the names.
Thanks!
Related to this:
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/36094/print-multiple-worksheets-in-flowmaster
Hello Jenny,
That's the way it happens. As the article you have referenced says, you have to select all the worksheets then right click and choose "Print Selected Worksheets". However the order you choose would be the way the worksheets would be printed (or saved to PDF). Also you have to ensure that all the worksheets you want to print (or save to PDF) should be open.
I tried this with a test model in the latest FlowMaster CONNECT Edition (v 10.02.00.01) and the same of the worksheet like "Pipe30in" or anything you choose appears on the worksheet printed (or saved to PDF) at the top automatically.
Here is the updated article for your reference;
Print multiple worksheets in FlowMaster
Let me know if this helps.
Yashodhan Joshi
Answer Verified By: Jenny Mital
Thanks Yashodhan!
