Surge tank detailed report - flow in tank and riser
I am modeling a differential surge tank. When looking at the detailed report, the results of "flow riser" is not as I would expect and I would like to make sure that I understand the definition of both flow columns in the report. Could you please confirm if my understanding is correct:
Flow riser: flow that goes through the top of the internal riser (when overspilling into the tank)
Flow tank: flow that goes through the orifice that connects the external riser to the tank.
If this is correct then I have an issue. I will share with you fictive dimensions of the surge tank in order to explain it better.
top of riser = 50 m; bottom of surge tank = 40 m; orifice elevation = 40 m
water elevation (WE) in the surge tank during simulation: 43 m < WE < 48 m
There is a valve downstream of my pipe network. The valve is closed at the begining of the simulation and opens after a few seconds so the level in the surge tank lowers. Using the "riser flow" data, I computed the volume of water that flows out of the riser.  After a few seconds of simulation, this volume exceeds the volume of water that is stocked in the riser at time = 0 sec. I don't understand how this is possible since the riser can't be filled by the top (water elevation in surge tank lower than top of riser).
Can you help me to clarify this point?
Dominique
  • Hello Dominique,
    Could you send a copy of the model files? This link has details on how to do this. This may help in looking into this issue.
    Scott
  • Hello Scott,
    I have uploaded the model files.
    The file name is: Copy_Bentley.wtgpkg.zip
    Thank you for looking at it.
    Dominique
  • Hello Dominique,
    I received your model. Could you clarify where you are looking at the results and what elements you have questions on? Also, there is a valve in the model, but the status of it remains fixed throughout the run. Because of this, there is no real change in the system over the course of the simulation.
    Scott
  • Hello Scott,
    Yes of course, sorry for the confusion.The results come from the detailled report for the component "Surge Tank-diff" (3rd before last in the report).
    The valve status should be set to " ouverture_4_turbines_en_sequence" which opens the valves.
    Dominique
  • Dominique,
    During a downsurge when water starts to leave the differential surge tank, water drains out of the riser, but at the same time water leaves the main part of the tank through the orifice. See diagram below.
    The "Flow-Riser" shows the flow through the riser and the "Flow-tank" shows just the flow between the main part of the tank and the riser (from either the overflow above the top of the riser, and the flow through the orifice).
    As an example in your model at timestep 21.0 seconds, the "flow-riser" shows as -14.4 CMS and the "flow-tank" shows as -7.7 CMS (negative values indicate outflow). From the Time history graph of flow in the adjacent pipes, you can see that 14.4 CMS leaves the tank at that time. So, this means that 7.7 CMS is going from the main part of the tank into the riser, and the remaining 14.4-7.7=6.7 CMS is draining down from the riser, with a total of 14.4 CMS leaving the tank.
    So, the volume of water leaving the tank is coming partially from the riser and partially from the water in the main part of the tank.
    I have made some updates to the Surge Tank Modeling Reference article to clarify these points.
    Jesse Dringoli
    Bentley Systems, Inc.
