We are attempting to run a 3 hour fire flow simulation in Watercad and there doesn't appear to be a tool for that function. A search has found a WaterGems solution but the client does not have WaterGems. The model needs to be returned to them in WaterCad with all scenarios functional.
Just to clarify - you are correct that the "EPS fire" tool mentioned in this article will only work for WaterGEMS. I agree with Scott's answer about using patterns as a first step - the EPS fire tool was intended for a very specific application.
