Hi people, it is not clear to me the Open Flow, can you integrate water, wasted and drainage? or will there be a suit that can do everything ??
open flow ops also serves for design? or only for existing networks...
Leonides,
OpenFlows is a brand within the overall Bentley portfolio of products.
There are two file schemas based on WaterGEMS and SewerGEMS. For example, with a SewerGEMS based file, you can share that file between SewerGEMS, SewerCAD, CivilStorm and StormCAD.
All OpenFlows products share a similar looking user interface and work flow which makes moving between them easy. Once you learn one, it's easy to learn another.
WaterOPS is a subset of WaterGEMS and contain only features that would be useful for operational use cases.
We currently do not offer any suite or bundle options.
Answer Verified By: Leonidas Dávila
To supplement Dr. Walski's answer, here is an article that explains more about WaterOPS: OpenFlow WaterOPS
...and here is a post that explains the "OpenFlows" brand: Introducing OpenFlows
