I'm modeling a pipeline that has a booster pump in the middle (something like the scheme below) and I would like to know if there is any inconvenience in separating the pipeline and creating two models to analyze the behavior when the pumps stops. I know I will have to apply the boundary conditions as if it were a single pipeline)
I ask this question because we do not normally model booster pumps / stations.
Hello Joao,
Here is information about modeling booster pump in water products, please go through it, its similar to normal pumps.
How do you model a booster pump in WaterGEMS/WaterCAD?
Sushma Choure
Bentley Technical Suppport
Hello Sushma,
Thank you for your answer. I had already gone through this article and assembled the model according to the indications that are there.
The problem I'm having with this model (booster pump in line), is that when we start working on protection against the water hammer (sudden shut down os the pumps) it is impossible to eliminate the depressions in the area closest to the booster pump. But by separating the pipeline in two branches, it is already possible to eliminate the depressions at the two branches. The purpose of this analysis is to ensure that the minimum pressure is above 0 bar.
Thanks for the clarification, I understand your concern now. I believe by depressions in the area you mean low pressures.
Are you using any surge mitigation device? If yes could you please provide the details?
It will not be a good idea to separate the pipeline in two branches if it is not the case on field. You should model the elements as they appear on field.
Yes, I'm using Hydropneumatic Tanks. One in the pump station and other in the booster pump (just like the scheme i sent before).
My bad to ask you about surge mitigation device which could be clearly seen from the screenshot attached by you in problem description.
Could you please upload model files for our review, if possible to help you with the issue.
Sharing model files.
