Hi
Good day, just to ask a question, how do I model Soak away Manhole/Chamber with infiltration on the bottom of the chamber and the Stormwater inlet is connected to it, see drawing below.
Thank you for the response.
Hi Yashodhan Joshi,
Yes you're correct, my problem is not the ditch/swale but the chamber with infiltration (the bottom is open), how to model it to civil storm.
Thank you.
Hello Gregorio,
As I suggested in my first response the way to achieve this would be to model an underground storage chamber with seepage at the bottom.
This can be done using the pond element to specify the storage chamber characteristics with a seepage method specified (viz. average, constant) to account for the seepage at the bottom of the storage chamber.
A similar query was discussed on this forum some time ago. Here is the discussion;
Forum Post - Setting Up a Storage Chamber in CivilStorm
Similar to your query the user in the above post was inquiring about seepage at the bottom of a storage chamber.
Let me know if this helps.
Yashodhan Joshi
