Need help working from home with your Bentley software? We're here to help - click here
Two Tanks, One High, One Low
I have a situation with two tanks in my model (WaterCAD, standalone).
The current set up is thus:
The model - The larger of the two tanks is at a higher elevation, as are the piping and junctions for the larger tank. The smaller of the two tanks is at a lower elevation, as are the piping and junctions for the smaller tank.
Here are the current operating parameters of the two tanks:
T-1
Elevation (ft)                   553.46
Elevation (Base) (ft)        553.46
Level (Minimum) (ft)      17
Level (Initial) (ft)              18.5
Level (Maximum) (ft)     19.5
T-2
Elevation (ft)                   550.52
Elevation (Base) (ft)        550.52
The issue - The larger of the two tanks is flowing into the smaller tank according to the model (makes sense if the system is gravity fed). I need the two tanks to run in parallel because that is the current operation.
The question - If the system is completely gravity fed, what valve or valves do I need to use to prevent the larger tank from flowing into the smaller tank, and have both run in parallel operation? I need both tanks to contribute to the system. I assumed a check valve would work to prevent the larger tank from flowing into the smaller tank, but I have no experience using them, so I am hesitant to.
Thank you for reading all of this,
Clint Taylor, EIT
