Land Use_SewerGEMS
In Bentley SewerGEMS, I could not find globe edit for the land use in the flex table, and can not add Percent of Catchment to the flex table. I would like to assign the land use to the catchments and I have around 3,700 catchments, is there a way; or I have to do it manually (one by one)?
Also for the initial Buildup.
Mohamad
Parents Reply Children
