Hi i trying to do a Skeletonized version of my model leaving only principal mainlines. I made a Selection Set with the principal mainlines only, *** are the pipes i want to protect from branching but i m stock with a version in *** the pipes dondt colapse anymore. Any ideas how to enable the model to continue skeletonizing the model even more? How can i enable a pipe that does not remove to be ok for manua or outo l branching?
Jose Angulo,
If the model is not taken down to only principal mainlines after you run Skeletonize, you can run it again.
If this does not answer your question, please elaborate or send me a copy of your model for analysis. Here is a Wiki with instructions on uploading files for analysis.
Larry
Larry I ran the motel again an did not work
Help me taking down the model to just protected pipes using skelebrator tool.
This is my model.
Prueba.wtgpkg.zip
Hello Jose,
Model uploaded by you is already too skeletonized, which branch pipes you are exactly targeting in this model?
When i placed few branch pipes randomly and used branch collapsing for pipe diameters say less than 100 mm it did delete these newly created pipes.
Please elaborate, to help you further.
How do you use Skelebrator on only a certain selection set of elements?
Sushma Choure
Bentley Technical Suppport
