Elements size
I am using WaterGEMS and have created the initial layout of the water supply system.
The layout still doesn't consist pipes, it consists only the other system elements (tanks, pump stations, pressure valves etc.) geographically located at proper positions.
Also, for this purpose I use the Bing background map.
When I zoom the map to extents (zoom level 0,2%) I cannot see any of the system elements because obviously they are too small to be drawn at the map, and I have to zoom in pretty much (almost to 100%) so some of them become visible.
My question is how to make elements visible (increase their layout size) and make them visible regardless of the zoom level?
Thanks in advance,
Dean
