OPENMP: Max number of threads available is 4OPENMP: Using the max number of threads available
Please can you resolve my problem where is a mistake done?
Hello Sunayana,
Can you confirm if you are using MOHID Land? or OpenFlows FLOOD?
OpenFlows FLOOD (formerly MOHID Studio) is our product for flood modeling. If possible share a screenshot of the error and also elaborate on the steps you followed which resulted in this error.
Yashodhan Joshi
Hi Sunayana,
The message you have posted above:
it is simply a log message warning you that when the model simulation is launched OpenFlows FLOOD engine MOHID Land is looking at the maximum number of processors your computer (in your case 4) and it is warning it will use all of them.
Is there any other warning/error message below the one you've posted?
Thanks and regards,Luis
Answer Verified By: Sunayana Chandra
Hi again,
The error above "ConstructGlobalVariables - HorizontalGrid - ERR20" appears because the file that you've defined as the digital terrain model file in the Model Domain properties is not in the correct format.
I think this is happening because you have define a different file in the Digital Terrain Model To learn how to create this file you can find more information here or here.
Once it is created you can set it associate it to the model domain as explained here.
Please let me know if this solves the problem.
Kind regards,Luis
