today I have updated sewergems to 10.03.00.77 version but its not working with arcgis 10.5...….plzzz help
Have you tried re-integrating ArcGIS with SewerGEMS?
Go to Start > All Apps > Bentley > Integrate SewerGEMS with ArcGIS-AutoCAD-MicroStation. Re-run this and see if this helps. See the below article for more details on troubleshooting ArcGIS integration;
Troubleshooting ArcMap / ArcGIS Integration
Let me know if this helps.
Yashodhan Joshi
I tried them... not working....can we degrade the sewergems to previous versions....if we can...help me..
Thank You.
It is possible to downgrade, but that shouldn't be necessary. I typically see an issue like this resolved by running a Repair on SewerGEMS through the Control Panel. Those steps are included in the link Yashodhan provided.
Otherwise, can you let us know what the issue is? Is there no shortcut? Are the menus missing?
Scott
yes sir,,the menus are off.....I am trying to click on menus....not working..i was able to click and edit them on previous version....ever since I updated it...the problem is happening...
Please confirm if you have tried to "re-integrate" and "repair" as mentioned in the solution I have given in the first response.
When you create a new model in SewerGEMS for ArcGIS, are you able to "Start Editing" in the Editior tool? This would activate all the SewerGEMS menus. See attached screenshot below;
