Why is my color coding element symbology not working? For example if I want to check the velocity of the pipe. the color won't change as stated in the legend. It says as one color. what ever is at the beginning of the run.
If you have defined color coding for multiple properties (e.g. Flow), you may need to uncheck Flow for Velocity to show up.
I have only velocity layer on. The color stays the same though out the time browser. However, it changes it I turn the layer off and on at certain time. For example say I pause the time browser at 48 hour and turn the velocity layer off and on, the color changes to the appropriate legend but in continuous run in time browser it won't
Hello Iskal,
Try moving just the .wtg and .wtg.sqlite files to a new folder, then recompute and see if that helps.
If not, please let us know what version of the software you have and send a copy of the model files to us.
Scott
It sounds as if you may not have auto refresh turned on - see: Annotation or Color Coding not updating when scrolling through Time Browser or Changing Scenarios
If this does not help, the bottom of the article includes Scott's suggestion of isolating the .WTG/SQLITE files in case the issue is due to a corrupt .DWH files. However this may not help if the issue happens with all model files (try one of the sample models included in the "Samples" subfolder within the installation folder). If it happens in all models and auto-refresh is turned on, try updating your video hardware drivers as mentioned at the top of this article (plus see items 7, 8 and 11)
I unloaded the file
