Depth /Rise
Greetings,
Please I need to know the different between Depth (maximum) / Rise, and Depth /Rise and Depth (Normal) / Rise.
And how can I evaluate the pipes based on d/D while the constrain of the percentage of full is 75%.
The same pipe has different % of Depth (maximum) / Rise, and Depth /Rise and Depth (Normal) / Rise. please carify
  • Hello Peter,
    The depth / rise (%) field changes as per the solver you are using.
    If using the Implicit Engine the "depth" is the depth in the middle of the conduit
    If using the Explicit Engine the "depth" is the depth value calculated from the Explicit engine
    If using the GVF-Convex or GVF-Rational Engine the "depth" is the depth in the average depth in the conduit
    Similarly,
    depth (normal) / rise (%) indicates a ratio of "normal" depth by rise and depth (maximum) / rise (%) indicates a ratio of maximum average depth by rise.
    You can consider the depth / rise (%) at every time step and check how your constraint of 75% full capacity is satisfied at every time step. You can also consider the depth (maximum) / rise (%) to know the percentage full when the maximum average depth is considered against the rise.
    We have a documented wiki on this. Please see the article below for reference;
    Depth over rise results for conduits
    Additionally, in future if you want to know the definition of a particular term you can look up the description of it at the bottom of the properties tab. See the snapshot below for your reference;
    Hope this helps.
    Yashodhan Joshi
    Answer Verified By: Peter Ghali
