Error 'Object reference not set to an instance of an object'
I am trying to open a hydraulic model and I get the following message: Object reference not set to an instance of an object. I checked on the forum and I found that one of the solution would be to copy the .wtg and wtg.sqlite files on a separate folder. I tried even this method and still I have received the same error message. The version of HAMMER which I am using is V8i  08.11.06.58 64-bit.
