Sushma Choure
Bentley Technical Suppport
Answer Verified By: G Gurumoorthy
Hai Sushma,
Thanks for your Kind reply.
Question 1;
We have taken from the Road Centreline Dxf file and Using Model builder to imported in Sewergems. After that u check it in sewerpipe, some of the pipes Bend will come. As your answer is correct. If we selected one pipe and remove all bends in ONE PIPE only. This process is suitable for 10 to 100 pipes. IF i had 10000 pipes means?.I am asking, like this method we cannot select all the Pipes and Click Remove all Bends. It is POSSIBLE OR NOT?. If not possible, please suggest alternate methods.
Question 2;
I will Check it. If any doubt, i will ask you.
Question 3 and 4
No issue. Understood.
Guru
G Gurumoorthy said:Question 1; We have taken from the Road Centreline Dxf file and Using Model builder to imported in Sewergems. After that u check it in sewerpipe, some of the pipes Bend will come. As your answer is correct. If we selected one pipe and remove all bends in ONE PIPE only. This process is suitable for 10 to 100 pipes. IF i had 10000 pipes means?.I am asking, like this method we cannot select all the Pipes and Click Remove all Bends. It is POSSIBLE OR NOT?. If not possible, please suggest alternate methods.
At this time the "remove all bends" is done one pipe at a time. See also here. If you do not want the bends to be included, you could manipulate the source data in AutoCAD (or MicroStation) and re-import with ModelBuilder to update the geometry in bulk.
