HiI need to know, how do something with the watergems. I need to make a quicly urgent report.I need to kow, how WaterGEMS can calculate the number of consumer that will stay without water, if I cut the water network on determined point.Is the WaterGEMS can simulate that?Thanks
WaterGEMS Connect edition update 2, version 10.02.03.06.
Wagner,
We can do what you want with our Criticality and Segmentation feature. Analysis >.Criticality.
If you have all the isolation valves in the model and you have customer meter elements with taps and lateral connection assigned, WaterGEMS can do a very accurate job.
If you don't this exact information, then we can give you results but they are a bit more approximate because we don't know exactly what side of a valve the customer is located. WaterGEMS needs to make some approximations.
Tom
Wagner, to add to Tom's reply - see the following wiki article for more information on Criticality: Running a Criticality Analysis There is a tab on the right side which lists the affected customers.
I recommend updating to our latest version, 10.03.00.69. You will see notes in the above article regarding some improvements we've made recently, for best accuracy regarding the list of
If you are using SCADAConnect Simulator, see the following video for how the pipe break feature can be used to get a list of impacted customers from a pipe break event (similar to your case since the impact would be the same - the segment is taken out of service and some customers are cut off): https://www.youtube.com/watch?v=r-RDkX7qlqc
Thanks Tom Walski and Jesse Dringoli, but I was talking with the engeneers and we don't have information enough to do that. Thanks a lot.
