Hello Ali,
Could you please confirm which product are you using? SewerGEMS / StormCAD / CivilStorm?
Please make sure that you have entered the storm data for the event created on right side to make it appear in global storm events.
Different storm data types are applicable for different runoff methods, please make sure you using the correct one. Search for topic - "Storm Data and Runoff Methods " in help documentation.
Global storm events dropdown not showing all events
I checked your model in latest version and Storm event 1 was available for selection using dropdown menu in global storm events as seen below.
In Storm events tab I see some data missing for storm event 1 compared to other two events though.
However you are using an older version, 10.01.00.70, I am checking with that version and will let you if issue appears there on our side as well.
Sushma Choure
Bentley Technical Suppport
