Using the stormcad option, I am building a runoff system of a city and I am trying to use the automatic catchment delineation but I am getting the error written in the picture below. I think my terrain model is working because it succeded assigning elevations to the catch basins. I did put some of the dowstream trace to some of the catch basins to test it out, but still getting the same error. Thank you
Hello Dima,
The error message implies that the units in the terrain model settings are not matching that with the model units. Could you please confirm?
Also make sure that you are following the correct procedure to perform catchment delineation, per steps mentioned in below wiki.
Using Catchment Delineation
If required please upload model files and terrain model file for our testing.
Sharing model files.
Sushma Choure
Bentley Technical Suppport
Answer Verified By: Dima Gerlyants
Thank you for your answer.
I have checked the units and didnt see any mistake. I am sending the file now through the confidential files
thank you
name of the file: yafo
I was able to run the catchment delineation without getting an error message. It appears you may be using an older version of StormCAD. Please try installing the latest version to see if that helps.
Scott
Thank you. It did help me resolving the problem I mentioned above.
I get really small areas for most of the catch basins, the catchment does not cover the entire area of the drawing.
When you ran the program for me was it the same for you? Do I have a problem at the properties of the catchment delineation or is it the topography?
Thank you
