WaterGems: Problem with pipe line colour not changing.
I have some lines and notes in a WaterGems model that are refusing to change colour with everything else.  They are still calculating fine but are not following the Element Symbology colouring. I've checked symbology, alternatives and properties but cannot find anything different setting.  Any help appriciated.
Thanks Andrew
  • Hello Andrew,
    The elements which are not changing colors with element symbology applied, are inactive elements. Meaning they must be part of some other scenario or made inactive by mistake.
    Select any of those elements and check "Is Active" field in elements properties, it must be set to false.
    You can either make them active individually using properties or use active topology selection or active topology alternative.
    Please use active topology to make those elements active and to be part of design. How to use active topology options is explained in detail below.
    Active Topology Management
    Sushma Choure
    Bentley Technical Suppport
  • Sushma,  I changed the "Is Active" to false (they were already showing True), Ran a Compute then changed the Is Active back to True and all working and showing properly.  Thanks for your help greatly appreciated.
    Andrew
  • Andrew for the future, you may also want to check and make sure that Auto-refresh is enabled. See item #7 here.
    Jesse Dringoli
    Bentley Systems, Inc.
