Dear Bentley Team,
After pump trips (Shutdown after time delay case) why continuous reverse flow showing on graphs, it should reach zero flow after some time, but graphs are not showing the same. Once flow is reached to zero then graph should end even though we consider any run duration time. Please refer attached graph with PINK highlighted color, continuous reverse flow showing in between -200 l/s to -300 l/s, not reaching to 0.0 l/s.
Same as flow, pump speed graph showing that pump is continuously running reverse, it should reach zero speed after some time, but graphs are not showing the same. Once speed is reached to zero then graph should end even though we consider any run duration time. Please refer attached graph with RED highlighted color, continuous reverse speed is showing in between -750 rpm to -1000 rpm, not reaching to 0 rpm.
Could you explain why theses graphs are showing like this, as client is not accepting this graphical representation.
Thank you
Hello Jayakanthan,
Please check if you have setup a check valve downstream of the pump with a delayed closure. Due to this delayed closure there could be reverse flows in the pump. Also check the pump properties and see if you have set the "Reverse Spin Allowed?" property for the impeller to "True".
If you are using instant closure in the check valve, then check to see if an air or vapor pocket is forming between the location you are graphing and the check valve. If cavitation occurs, the water column can flow in reverse as the air/vapor pocket increases in size.
See the below article on Check Valves and their use in HAMMER for reference;
Modeling Reference - Check Valves in HAMMER
Let me know if this helps.
Yashodhan Joshi
In pump discharge we do not have any check valve & pump discharge going to higher level than pump elevation, so during pump trips, water will fall down towards pump hence we chosen "Reverse Spin Allowed".
As per given graphs, reverse flow & speed is not coming back to to zero & values should reach zero in reality, but these graphs are not showing zero after running simulation for long time as well.
In case of "Reverse Spin Allowed"- "set as NO" then speed is coming back to ZERO after some time, same way in case of "Reverse Spin Allowed- "true" why speed values are not coming back to ZERO after long time also.
Request you to check & provide the resolution.
Jayakanthan,
Is a vapor or air pocket forming in your system? I would recommend examining a profile animation in the Transient Results Viewer to see if this occurs. if so, it could be that the pressure remains low enough with the pump shut down that a vapor or air pocket continuously increases in size, and the flow you see is the water column moving away from the pocket (and toward the pump). By default vapor and air pockets are limited to the location of formation (the liquid interface is not tracked unless using the Extended CAV option for air valves), so HAMMER does not know how long it would take to drain out and reach a zero flow condition. See related article: Assumptions and limitations of tracking air or vapor pockets in HAMMER
If this is not the case or if you are not sure, please provide a copy of the model and steps to reproduce: Sharing Hydraulic Model Files on the OpenFlows Forum
Thank you for your reply,
I have shared simulation file with option-2 method & file name is "Reference simulation file.rar"
Request you to check & provide solution. Client is not accepting this software graphical representation as after running simulation long time also speed & flow not reaching to zero condition.
Hello Jayakantan,
As Jesse suggested this is due to air pocket formation which is causing the air volume to increase without going down. As air pockets are not tracked beyond their point of formation it never reaches zero and the column separation continues to push water away from that point towards the pump. See the animated profile below;
See the air volume continuously increasing after your pump shutdown event. This shows evidence of an ever increasing air pocket.
