Model File not Opening correctly
I received a model from a client for WaterGEMs and i have two things happening depending on which of their models i attempt to open. The first is when i open the model from February and it loads fine and when i try to run it says validate. Once i validate the model i get the following screenshot.
/resized-image/__size/320x240/__key/communityserver-discussions-components-files/5925/pastedimage1591876157653v1.png
The other model they sent when i try to open it yields the following results:
My company has assured that i have the newest version of WaterGEMs installed however
