CivilStorm EGL and HGL Jump
Dear sir / madam,
I am using CivilStorm (Explicit SWMM Solver) for running a storm sewer network and I noticed hugh EGL and HGL jumps all location. So what I found out is that there are no outflow leaving the system, and the inflow of several thousand cfs into the network when it should only be less than 20 cfs in total really. The model was imported from Geopak Drainage and I tried to look for the any input that might be causing this but cannot find
