I'm new with waterObjects.net and I'm trying to run the samples provided in order to learn how can I achieve what I need to do with my WaterCAD model. Unfortunately I suffering lots of problems with almost all of them.
In particular I have the same problem as the one on this previous post (EngineAdapter FileNotFoundException problem) where appears "module not found" problem. But, I did all the suggested actions without luck.
This is my output.
The thread 0x4320 has exited with code 0 (0x0).Excepción no controlada: System.IO.FileNotFoundException: No se puede encontrar el módulo especificado. (Excepción de HRESULT: 0x8007007E) en WaterObjects.NET.PressureEngineRunner.PressureEngineRunnerForm.RunEngine() en WaterObjects.NET.PressureEngineRunner.PressureEngineRunnerForm.buttonRun_Click(Object sender, EventArgs e) en C:\Projectes\Taigua\WaterObjects_Samples\WaterObjects.NET.PressureEngineRunner\Development\WaterObjects.NET.PressureEngineRunner\PressureEngineRunnerForm.cs:línea 318 en System.Windows.Forms.Control.OnClick(EventArgs e) en System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent) en System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks) en System.Windows.Forms.Control.WndProc(Message& m) en System.Windows.Forms.ButtonBase.WndProc(Message& m) en System.Windows.Forms.Button.WndProc(Message& m) en System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m) en System.Windows.Forms.NativeWindow.DebuggableCallback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam) en System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg) en System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(Int32 dwComponentID, Int32 reason, Int32 pvLoopData) en System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context) en System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context) en WaterObjects.NET.PressureEngineRunner.PressureEngineRunnerForm.Main() en C:\Projectes\Taigua\WaterObjects_Samples\WaterObjects.NET.PressureEngineRunner\Development\WaterObjects.NET.PressureEngineRunner\PressureEngineRunnerForm.cs:línea 79The program '[22892] WaterObjects.NET.PressureEngineRunner.exe' has exited with code -532459699 (0xe0434f4d).
Can anyone help me with this?
Or alternative, can someone provide a simple sample example with what I'm trying to do?
My goal is Open and Compute a WaterCAD model. Read some results, modify/update the demand base parameter on a certains demand nodes and compute it again.
My versions are:
WaterCAD: 10.02.03.06 64-bit.
WaterObjects: wonetsdk10000001en.msi
Visual studio community 2019
Thank you in advance
Juli
