I have an issue with my Hydraulic Model.
I have analysed my model with two different approaches.
Used user-defined gutter-> Conventional-> Max Gutter depth 0
Used max gutter depth 0.06 m in this case(global edit in Catchbasin FlexTables)
Now the issue is, in second case it looks like the network is not capturing the full flow from the catchments. I checked the total flow from catchment contributing to a pipe and checked the flow in the pipe, they are not matching. In case 1 its matching.
I want to know if I had done a mistake. Please help me through this.
Case 1 Images:
Case 2 Images:
Hello Kartheek,
Check the capture efficiency of the catch basins in the second case. What is the inlet location you have set for the second case? Is the inlet "On Grade" or "In Sag"? If the inlet is "In Sag" it will capture 100% of the flow. However, it is also possible to have full capture with "On Grade" inlets. We would need to take a look at your model to see the results and identify if there is some data input problem.
Please share the model files (.stsw and .stsw.sqlite) for our testing. See the article below for details on sharing model files on the forum;
Sharing Hydraulic Model Files on the OpenFlows | Hydraulics & Hydrology Forum
Yashodhan Joshi
Hi Joshi,
I have uploaded the files for two cases. Please have a look
Kartheek
Hi Kartheek,
I have taken a look at the model files and I see that in both cases all of the flow is captured, but the ponded area that you have chosen to add above the rim is causing the inlet inflow to be attenuated in the case where the inlet type is set to Catalog Inlet. You can see this by graphing "Flow (total in)" along with "Flow (total out)" for the catchbasin.
I believe the reason why this does not happen when the inlet type is set to full capture is because in this case, the gutter is not considered, so the ponded area above the gutter does not come into play, and thus the catchment runoff enters directly into the catchbasin. (if overflow later occurs, the ponded area would be considered).
In the case where the inlet type is set to catalog inlet, gutter hydraulics are enabled, and the program considers the impact of the ponded area. Catchment runoff first enters the ponded area and then becomes attenuated as it enters the inlet, similar to pond hydraulics with outlet structures. I am discussing this internally with our developers to confirm that this is indeed expected behavior. In the meantime, please confirm if you intended to have a large ponded area above the inlet.
Hi Jesse,
I have changed the Ponded area at inlets to lower value(50m2) and the flow values are almost matching. But two new issues raised.
1. There is huge overflow loss in 10-Year Scenario and
2. The Hydraulic Profile is looking bad in few places of network. I have attached one image for your reference. Check the maximum HGL of first inlet.
I am unable to understand where it went wrong. Please help me through this.
This is the overflow from the catch basins. Due to less storage area (50 sqm) now, there is overflow at the catch-basins which is causing the high HGL values. Try to use the gutter element in parallel to your catch-basins to capture the overflow.
Basically what is happening is that once the storage area for your "In Sag" inlets is getting filled up; its overtopping with overflow and hence the high HGL values.
