Backround layers
Whn I load a backround layer it does not show up. I have loaded DXF and SHP files and cannot see them. Can you help me with this?
  • Hello Kevin,
    Try doing a Zoom Extents to see what happens. If the DXF or SHP files are not on the X:Y coordinates as the model you may see something like this. This link has some information on this.
    If that is the case, I would recommend using the original platform for the file (AutoCAD, MicroStation, ArcMap) to move the background layer to the correct location.
    Another thing you can try is to open a new model and load the background. You will likely need to do a Zoom Extents to see it. You can note the coordinates for the background layer compared to the model coordinates.
    Scott
  • Hi Kevin,
    This Wiki article suggests when attaching background files, try turning off the option to Use Compression and see if the background displays.
    Let me know if this helps.
    Larry.
