Hydraulic in watergem
1.Can i get soln  for control to select automatic size of pipe diameter rather than importing manual?
2.i always inport my data via epanet model but ts weakness my data miss lebelling. In preparation of excel to epanet i use excel tools to epacad then to epanet this always not importes with lebelling feature! How can i solve this?
3.it takes to longer to join point to point ( node to node) in order to get lines in arcgis using digitize..is any means of connect line automatically in arcgis for shapefile preparation??
  • Hello Gadama,
    1. Darwin Designer can be used to help size pipes. Details on using this are available in this link: Using Darwin Designer to design pipes in WaterGEMS.
    2. What sort of labels are you trying to import? I did a test import and the element labels appeared to import just fine. If there are other labels, this will likely need to be added to the WaterGEMS model using Element Symbology. This link has information on importing EPANET files in WaterGEMS, and the limitations with that.
    3. ModelBuilder will be useful to import a scaled representation of a GIS shapefile. You can find details on using ModelBuilder here: Using ModelBuilder to import external data.
    Scott
    Answer Verified By: Gadama Kulwa
  • Sir thanks.....but how can get video showing preparation for arcgis shapefile??
  • Hello Gudama,
    To prepare the data is a GIS format you can use ArcGIS or any other GIS platform. However, you would have to do this operation and prepare the data to import via ModelBuilder as Scott suggested.
    If you are facing an issue in preparing the GIS data you can import via ModelBuilder using the Excel and the CAD data you mentioned. Refer the article Scott shared about importing external data.
    Yashodhan Joshi
  • Thanks sir for your claer elaboration....when i use CAD file elevation always not imported as usual but when execl file i imported some erro occur
    1.point seem to be imported in flexible table but not seen in screen measn ts layout
    2.when i zoom to extent no points appear too
    3.how to import automatically line connected in excel format
  • Hello Gadama,
    For items 1 and 2, if the symbol size is small, that might account for why the elements do not appear. You can change the symbol size for all elements in by going to File > Options and going to the Drawing tab.
    You can also adjust the drawing style either in the Options dialog or in Element Symbology.
    If that doesn't help, try doing a Zoom Extent (View > Zoom > Zoom Extent)
    For item 3, if you have pipes in an Excel file, you can add this using ModelBuilder as well. However, since the Excel file doesn't include spatial data, you would need to have columns in the spreadsheet for the Start Node and Stop Node. This are required because ModelBuilder will then know where to place the pipe.
    If you have the pipe network in another format, like a shapefile, this tends to be easier to use. Since the spatial data is included in the shapefile, you do not need to assign a start and stop node.
    Scott
Reply
  • Hello Gadama,
    Scott
