I need to build model from shape file and Manhole file contains only ground level and conduit comprises on invert level - so what option i can use to build the model so conduit can pick invert level start and stop from shape file.
Regards;
Hello Muhammad,
Depending on the format of the data, you may be after to use ModelBuilder to apply the conduit invert elevations to a node, such as a manhole. The following link has information on doing that: How to apply conduit start/stop elevations (eg. ground & invert) to adjacent nodes.
Scott
Thanks Scott - This article is useful.
