Tengo probemas con watergems for arcmap
Tengo problema en conectar un archivo a Argis, el cual indica  el problema indica"Unhandled exception has occurred in a component in your application. If you click continue, the application will ignore this error and attempt to continue Exception from HRESULT:0X80040213", alguien podría ayudar por favor
  • Hi Jesus,
    Using Google Translate - original question:
    I'm having trouble connecting a file to Argis, which indicates the problem states "Unhandled exception has occurred in a component in your application. If you click continue, the application will ignore this error and attempt to continue Exception from HRESULT: 0X80040213", someone could you help please
    English: I am not part of the tech support team, but I will try to help.
    Sounds like you are having trouble opening a file in WaterGEMS for ArcMap. Is this a new issue (were things working ok recently)? And, is this issue only occurring for this one particular file? e.g. Are you able to open one of the Sample files?
    Spanish: No formo parte del equipo de soporte técnico, pero intentaré ayudar.
    Parece que tiene problemas para abrir un archivo en WaterGEMS for ArcMap. ¿Es este un problema nuevo (las cosas funcionaban bien recientemente)? ¿Y este problema solo ocurre para este archivo en particular? p.ej. ¿Eres capaz de abrir uno de los archivos de muestra?
    Rob.
  • Gracias, si es un problema nuevo y al parecer es por ese archivo.
  • Hi Jesus,
    Translating your last message:
    it's a new problem and apparently it's because of that file
    English: Thanks for the additional details.
    I suggest you first make a backup copy of your geodatabase and WaterGEMS files (be sure to backup the wtg, wtg.sqlite, and (if there is one wtg.dwh).
    It looks like there is an issue opening the Geodatabase itself.  You can try to verify that by starting a new ,mxd file, choose "Add Data", add that same geodatabase (FeatureDataSet) to the map, and see if that succeeds.
    Additionally, the Geodatabase can be recreated without losing your modeling information.  If you want to try that: 1) Create a new .mxd file, 2) using the WaterGEMS Hydraulic Model Manager, "Add Existing Hydraulic Model", 3) select that same WaterGEMS file, 4) when prompted, create a new Geodatabase with comparable settings (spatial reference, domain extents) that were used for your original.
    Spanish:  Gracias por los detalles adicionales.
    Le sugiero que primero haga una copia de seguridad de su geodatabase y archivos WaterGEMS (asegúrese de hacer una copia de seguridad de wtg, wtg.sqlite y (si hay uno wtg.dwh).
    Parece que hay un problema al abrir la Geodatabase en sí. Puede intentar verificar eso iniciando un nuevo archivo mxd, elija "Agregar datos", agregue esa misma geodatabase (FeatureDataSet) al mapa y vea si eso tiene éxito.
    Además, la Geodatabase se puede recrear sin perder su información de modelado. Si desea probar eso: 1) Cree un nuevo archivo .mxd, 2) utilizando el Administrador de modelos hidráulicos WaterGEMS, "Agregar modelo hidráulico existente", 3) seleccione el mismo archivo WaterGEMS, 4) cuando se le solicite, cree una nueva Geodatabase con configuraciones comparables (referencia espacial, extensiones de dominio) que se utilizaron para su original.
    Best regards,
    Rob.
  • As a supplement to Rob's answer, here is an article from our Wiki (in English) with information on restoring the geodatabase (and more)
    Troubleshooting ArcMap / ArcGIS Integration
    En español:
    Como suplemento a la respuesta de Rob, aquí hay un artículo de nuestra Wiki (en inglés) con información sobre la restauración de la geodatabase (y más)
    Jesse Dringoli
    Bentley Systems, Inc.
