Dear colleagues,
I need to have two alternatives for air valves, which I have to attach to particular scenarios, e.g. the first one is for air valves with equal outflow and inflow orifices, the second one is for air valves with different orifices for outflow and inflow. I cant find for now such thing.
And for example to combine alternatives for active and inactive pressure relief valve with this (unknown for me) two types of alternatives relative to the air valves.
If there is no such a tool, I can use flex tables and global edit, but if there is alternatives for that, it will be better.
Best regards
Boyan
Hello Boyan,
Assuming you are using HAMMER, this information is stored in the Transient alternative. You can create two of Transient alternative with two different air valve settings for two scenarios. You can find more information on managing scenarios and alternatives here: Scenario and Alternative Management.
Scott
