Flextable
Hi, i like to thanks for ur responding,  it real work and helpful. I have project taking water from spring and flowing by gravity up to my proposed storage tank....my problem is velocity in my garvity main in very large than recommended!!! When i try to increase pipe diameter velocity also increase and flow and vice versa so how can i control this, is anyway can i command flow???
  • If the spring is significantly higher than the tank, then you may need a control valve to reduce the pressure and control flow. Usually, a PRV would be adequate but you may also want to use a TCV with controls such that when the tank gets full it shuts off and when it drops to some lower level, it opens.
    To decrease flow, you can use a smaller pipe which will increase head loss since the head available is essentially fixed.
    If there is a great deal of excess head, you may even want to recover energy with a turbine.
  • Gadama Kulwa,
    Just to support Dr. Walski's comments, here is a Wiki Article - Modeling Reference - Valve Closure.
    Let us know if this helps resolve your issue.
    Thank-you,
    Larry
