Hi...how can i prepare shapefile in arcgis?
Hello Vasco,
I think this is related to your earlier query which I have responded here: Forum Post - Modelbuilder
You can also reach out to the ESRI support page for queries related to ArcGIS here: https://support.esri.com/en/
However, if you have an existing model in WaterGEMS you can export the data to shapefiles for those elements. To do so you would have to go to the element flex table (pipe, junction etc.) and in the top left corner select "Export to File" and choose .shp (which is the shapefile format) to export. See the below article on this for details;
Exporting model elements to shapefiles
Hope this helps.
Yashodhan Joshi
