I am currently working in HAMMER update 3 and still having the issue referenced in this article - https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/23768/hydropneumatic-tank-extended-node-data-graph-shows-linear-continuous-increase.
I hope someone can clarify my misunderstanding.
Youssef
Hello Youssef,
The Report Period field defaults as zero to help keep the size of the HAMMER output file lower. In addition, the user may want to only include report periods for select elements, like the hydropneumatic tank. It would be easier to adjust this for a handful of elements compared to adjusting it for most elements.
Regarding the location of the Report Period, it is stored in the Transient alternative. While your scenarios may not share the same alternative, if the base Transient alternative includes a Report Period for the hydropneumatic tank, the child alternatives should inherit this field, thus allowing you to keep a report period for multiple scenarios.
If you want to include a Report Period of a certain value when an element is first created, you can use the Prototype feature. This allows you to set what the default settings for an element will be.
Scott
Hi Scott,
Excellent tips, thank you so much for clarifying. Have a nice day.
