Sewersgems to Civil3D pipe network
I'm trying to convert my Sewergems model to use with 3D pipe networks in Civil3D in order to create plans and profiles. I've tried importing by using export to Landxml in the standalone sewergems program but when it imports in Civil3D the pipe size attributes don't carryover. The rim and inverts of the structures carryover fine. Is there a way to correct for the pipe sizes?
