i want to restrict flow from reservoir not more than 10000 gallon/sec. how i will manage it in watergem.
You can model it with a Flow Control Valve (FCV).
But that flow is incredibly large. I don't think they make valves that large.
Exactly what is you ruse case?
Thank you very much for giving me reply. i think it 10000 gallons/day not gal/sec. now its make sense.
Hello Mubashir,
As Tom suggested, you can use a Flow Control Valve (FCV) to restrict flow from your reservoir. See the article below for more details on using a Flow Control Valve;
What is the difference between a Throttle Control Valve (TCV) and a Flow Control Valve (FCV)?
The above article provides differences in a FCV and a TCV. However, the operation for both of them is explained in detail.
Hope this helps.
Yashodhan Joshi
Thank yoy for reply, sir where i will install FCV valve before pump or after pump.
The valve would need to be after, but is there an actual FCV after the pump in the system? If not, it might be better to just use the pump. Or you could set the pump as a variable speed pump with a fixed flow. This would adjust the speed of the pump so a given speed is generated.
Scott
