Dear all,
I would like to know: is there any method to select more than one column in flexTables (Hammer 10.01.01.04)?
Also, to select a column in flexTables (Hammer 10.01.01.04) you must click right on the desired column then copy (Ctrl C is inactive) , is there any other method?
Best Regards,
Moustafa Darweesh
Hello Moustafa,
Best way to select multiple columns would be to export the flex-table to a CSV file format and open it in a spreadsheet application (like MS Excel); then choose the columns as desired. See the below article which explains how to export flex-tables to different available formats;
Export data to an Excel spreadsheet
Let me know if this helps.
Yashodhan Joshi
Answer Verified By: Moustafa Darweesh
Hi Moustafa,
A few tips:
1) You can select a range by navigating while holding down the shift key (this is a fairly common behavior in Windows applications).
2) You can hold the [Ctrl] key and press the [Down] arrow key to navigate to the last cell in the current column (right, left, up work similar).
So, if you want to select 3 columns starting here:
Hold down the [Shift] key and press the [Right] arrow key twice:
Finally, while still holding the [Shift] key, press [Ctrl]+[Down]:
Best regards,
Rob.
Dear Rob,
Thanks for your reply.
I think this method is true if the columns are adjacent to each other.
