Water Age (Maximum) - Export to Shapefile
It doesn't seem like there is a way to export the water age (maximum) results into a shapefile, since that is not a flextable column, which makes sense since the maximums are not necessarily associated with the same timestep.  What is the recommended workaround to obtain the water age maximum data for a scenario and plug that into a shapefile?  Using watergems connect edition update 3.
Youssef
