I have a client who is looking to change SCADA platforms. Is there a SCADA platform that works best with WaterGEMS and SewerGEMS software?
I am not too familiar with the SCADA connection functions as of yet. I see that data can be brought in via database options like excel or access or through and OPC connection. I have the opportunity to guide the client towards a program that works synonymously with the model. Which SCADA platforms have worked best for you all?
Hello Alyssa,
WaterGEMS works with a host of datasources, such as Excel, OPC or Citect. There are no specific platform which is required for WaterGEMS to extract the data. You have to identify the data source and if it is available then you can connect and fetch the data in your model. For more information on SCADAConnect Simulator, see the below article;
Using SCADAConnect Simulator
For SewerGEMS the database sources are similar to those in WaterGEMS. See the below article for SCADAConnect in SewerGEMS;
Let me know if this helps.
Yashodhan Joshi
Answer Verified By: Alyssa Cohn
