ScadaConnect SQL tag read fails
I have an issue reading data from an SQL database.
It is configured and working, but sometimes is not showing the data existing in the database.
I go to the  SCADA Signals, and try to access to the Historical data of a Tag.
In my case, it works OKup to April. But from then on, it begins to be messy.
I have 4 options:
- I look to a range, for example in July, and it appers.
- I look to the same range that it was apperaing previously, and now it doesn't appear.Usually, it show no data, but doesn't generate error.
- I look to a range, and it shows no data.
- I look to a range, and it generates and error, including a pop up.(08/31/2020 09:43:01.26 System.Data.SqlClient.SqlException: Error al convertir una cadena de caracteres en fecha y/u hora.)
As I say, I'm accessing the same database, with no changes in data types, but it mostly fails with fresh data.
Parents Reply
  • Hello Andreu,
    What are the time and date or regional settings on the computer? Also, can you send us a private message confirming your company name and email address. There is a patch related to SCADAConnect that we may be able to provide, assuming that you have a Select account with Bentley.
    Scott
