I am using SewerGEMS and recently got the validation error message 51007 "Pipe/channel networks must end with an outfall node". I have found the conduit that the message is referring to, but I cannot figure out why the error is occurring. The conduit is clearly connected to the proper manholes and I have followed the flow path down to the appropriate outfall node - no inactive elements along the way or discontinuities. I even used the Navigator Tool and Network Connectivity Reviewer to verify. Also strange, is I have been using this model and running many scenarios fine with no errors for weeks and all of a sudden this morning the error comes up.
What else can I do to resolve this?
Jose
Here are two articles to supplement Tom's answer:
User Notification "Pipe/channel networks must end with an outfall node."
Using Network Navigator
If this does not help, try the following:
If you still cannot resolve the issue, it would be best to share a copy of the model for review: Sharing Hydraulic Model Files on the OpenFlows Forum
Thank you both for the reply. I was able to find and correct the issue.
