I am trying to model a hydrant flow (not at a set residual) with known initial conditions & known emitter coefficient.
Is this possible? If so, how? The model is elevated tower controlled.. Software is WaterGEMS for Autodesk Civil 3D 2018 Connect Edition Update 2
Set and emitter coefficient on the junction or hydrant node.
Remember that this is just the water that will come out of the hydrant when you open it. It is NOT the "available fire flow".
Why are you trying to model this?
I am just curious if it can be done.
Hello Dick,
As Tom mentioned, you can have WaterGEMS calculated the flow through a hydrant based on emitter coefficient. This link has information on this: Calculating available flow at a hydrant.
Scott
Here is the link mentioned above:
https://communities.bentley.com/products/hydraulics___hydrology/w/hydraulics_and_hydrology__wiki/18541/calculating-available-flow-at-a-hydrant
Answer Verified By: Dick Schneider
