It appears the Extreme Flow Factor can only be applied to "Unit Sanitary Loads". Is there a way to apply peak factors to "Sanitary Pattern Loads/Base Flow"? For example, I have imported Property Connections and then used LoadBuilder to apply meter data to all the Property Connections. Now I want to apply factors to those Base Flows. Please advise.
Jose
Hello Jose,
SewerCAD (GVF-Convex solver), extreme flow factors can only be applied to unit loads. However there is workaround after loadbuilder run to convert base loads to unit loads and then you can use extreme flow factors. Please see below wiki for details.
Using Unit Loads and Extreme Flow Factors after a LoadBuilder run
Sushma Choure
Bentley Technical Suppport
