My hydraulic analysis wont run and looking into the issues. Where is disable the 3D length option in SS4?
Hi Theresa,
The "Use 3D Length" option is located on the Project tab of the Options dialog.
Best regards,
Rob.
Tools > Options
Theresa,
The screenshot in your post shows the user notification "the scenario failed to compute". Was this the wrong screenshot, or is this actually the error you are troubleshooting?
When you say "SS4", are you referring to the version of an OpenFlows product such as StormCAD, or are you referring to V8i SELECTseries 4 of one of the older legacy Civil products like GEOPAK?
Here is an article about the "failed to compute" error: User Notification: "The scenario failed to compute. Review your data and try again."
Also, this article documents the 3D length option, if you are using an OpenFlows product.
I am referring to V8i Selectseries 4. There is no Tools> Options. I ended up finding it under. Subsurface Utilties> Project> Project Defaults> 'Project Tab' unclick "Calculate Pipe Lengths Using Node Elevations (3D)"
