Stormcad
trying to open a  stormcad 5.6 file in Stormcad Connect. I get the following error.
  • Hello,
    Which version of StormCAD CONNECT Edition are you running currently? Please ensure that the old StormCAD 5.6 file (.STM) is from StormCAD and not another application like WinStorm. If its a WinStorm .STM file, see the below article for details on opening it;
    Opening a WinStorm .STM file
    If its a StormCAD 5.6 .STM file, then try opening it in the 32-bit version of the current StormCAD CONNECT Edition. You can find this by going to "C:\Program Files (x86)\Bentley\StormCAD" and double-clicking on the StormCAD.exe file. See if that helps.
    There are additional troubleshooting options available in the below article which you can also try;
    Opening old StormCAD .STM or SewerCAD .SWR files
    Let me know if this helps.
    Yashodhan Joshi
  • yes it opens in the 32bit version..Can the file be converted to the 64bit version of connect? We have a client that is requesting the file be done in connect version of Stormcad.
  • When a model is saved, it is not saved for a particular "bitness". Once you save the model in the new version, it can be opened in either the 32-bit or 64-bit version. There is a note about this in the article that Yashodhan had shared:
    "Once the model file is saved in the current format, you will be able to work on the file in either the 32-bit or the 64-bit version."
    Jesse Dringoli
    Bentley Systems, Inc.
  • Thank you for your quick response.  The issue is the models and reports were created using Stormcad 5.6 sp2. We generated model and reports and submitted to our client. They commented that the model and reportsl were generated using Stormcad 5.6 sp2. They are requesting it in the connect version of Stormcad.
    thanks
  • Once you open and save the model in StormCAD CONNECT Edition, you can work on it there, produce the reports, and send the model back to the user (it will be in CONNECT Edition format). You may want to ask the client if they have a specific version of CONNECT Edition, as the products are not forward compatible. Meaning, if for example you opened and saved the model in the latest CONNECT Edition version 10.03.01.08, it cannot be opened in CONNECT Edition 10.02.XX.XX, 10.01.XX.XX or 10.00.XX.XX. See more here.
    Jesse Dringoli
