HI,
I am using OpenFlows Sewergem connect edition update 3. I am getting the following error while I am trying to export imodel. I tried with different versions, but getting the same error.
Dinusha
Hello Dinusha,
There are a few things that you can try. First, make sure that you have permissions to write to the location you are trying to save the i-model. You can try saving to your Documents folder or Desktop as a test.
Second, does this occur for only one file or for other models as well? If it is one file, you can send the file to us using the steps here and we can see if we can reproduce the issue.
Scott
Answer Verified By: DINUSHA P NARAYANAGE
Hi Scott,
Thanks for the reply. When I tried to save the imodel in my local drive, yes it worked.
I have posted information on the error message and solution here: Error publishing i-model: Could not add file level provenance.
Regards,Scott
