I'm working with sewercad to design and I'm kind of greenish.
Initially I had delineated my sewerline catchment manually based on the areas which would flow by topography to the sewerlines from a Gis software and created thiessen polygons from sewercad which were to distribute flows to the associated manholes based on those areas,But then the sewer lines fall into two wards.
How do I assign the loads using population density knowing that the two wards have different population density using the load builder with the upcoming challenges described?
Thank you
The Load Estimation by Population option may work for this. You can find info on this and other LoadBuilder types at this link. The Load Estimation by Population option includes an option for different population density types, which is a text field.
If you are using this already and having an issue, please let us know what the issue or error is.
Scott
